debrasheila's avatar
debrasheila
rax20
A site is being blocked on this computer but not on my other one. I am using Windows 10. model ax1800. I reset the router but that did not help.
  • plemans's avatar
    You have the RAX20?
    What modem/gateway is it connected to?
    What firmware is on it?
    What site is getting blocked?
    Does it say whats blocking it?
    Are you using Armor or parental controls?
    • debrasheila's avatar
      debrasheila
      ARRIS TM1602 MODEM
      Optimum ISP
      blocked site: epicmychart.optum.com
      Error message: DNS_PROBE_FINISHED_NXDOMAIN
      no Armor or parental controls
      Do not know about firmware
  • michaelkenward's avatar
    michaelkenward
    If both computers are on the same network connected through a single router, then it isn't likely that the router is doing this.
    They will both see the same settings on the router. A more likely culprit is the Windows PC that is blocking your access.
      debrasheila
      Thanks.
      The problem is the same using a different browser.
      Do you have any suggestions where to look? I am running Windows 10.  Security software is Windows Defender and Norton 360.
        michaelkenward
        debrasheila wrote:Security software is Windows Defender and Norton 360.
        Both PCs?
        You could try running the Windows Network Troubleshooter.
