allen_d
Feb 09, 2020Tutor
RAX200 2.4 band issues
Hello, Since purchasing the Nighthawk RAX200 router I have been having connetivity issues with some of my 2.4ghz band devices. These devices only connect to this band. The devices more specifical...
wingdam
Feb 22, 2020Star
I had the same type of problem after 2 factory resets nothing, so I reninstalled the latest firmware did a factory reset and it finally worked.
allen_d
Feb 22, 2020Tutor
I ended up returning the RAX200 and going back with the RAX120 minus slightly lower 5Ghz band speeds at range it is far less glitchy. I actually had the RAX200 randomly reboot a couple times, power cycle and not have it turn back on. Very frustrating.
