ronald_fr
Mar 27, 2020Luminary
RAX40 and iPhone 11
Hello,
I encountered some issues with 5G WiFi with various devices, hangs, reset to factory default.
No issue since a couple of days and :
Yesterday my iPhone 11 (IOS 13.1) had troubles with RAX40 WiFi 5G :
- on the iPhone >>> unable to access to Internet with WiFi 5G channel but works with WiFi 2.4G channel
- on the RAX40 >>> [WLAN access rejected: incorrect security] from MAC address xx:xx:xx:xx:xx:xx ...
- I rebooted the RAX40 and all worked fine after it.
Today same iPhone 11 (IOS 13.1) had same troubles with RAX40 WiFi 5G (same errors)
- I removed the "Enable AX" option on RAX40 & Apply
- and iPhone was able to connect w/o any issue
Need to know : this iPhone 11 is the only WiFi6 device .
... To be continued if any more news
RAX40 : Firmware Version V1.0.3.64_1.0.1
Sorry for my not perfect English as I'm French...
Thanks for any suggestions.
Or if it could help Netgear dev.
Ronald
- ronald_frLuminary
more about the issue : I also remove the AIRTIME FAIRNESS option to obtain better throughput on my laptop .
BR
Ronald
- Christian_RNETGEAR Employee Retired
Hello Ronald,
May you try changing the WiFi channel on the 5GHz band to see if there are any improvements.
Thanks,
Christian
- ronald_frLuminary
Thanks for reply,
but when I called Netgear support ( and paid for it :-( )
- They ask me to change channel and to put 128 ... it worked 2 days and it was worse !
- An other call to support : support rep. connected to my router and said "you are in AP mode, you must not change channel" and back to chan 44
- An other call to support : an other support rep. connected to my router and did not do anything more than the previous one and I said this is enough you don't have any idea or fix on thy brand new router (paid for nothing)
By now router is configured back to factory default with :
- AP mode
- unset "enable AX"
- unset 20/40 coexistence
- unset AIRTIME FAIRNESS
And it's now better for all devices working 2.4 Ghz and all 5Ghz as iPhones.
I only have sometimes some :
[WLAN access rejected: incorrect security] from MAC address... BUT FOR owned devices (camera printer iPhone)
To be continued if any news
Best regards
Ronald
I'm having this same problem with RAX40 and iPhone 11 Pro Max. Any updates on this? Does 802.11ax just not work? Thanks
- ronald_frLuminary
By now I have not tried to go back to 'enable AX' as I want to have a stable config (too many other issues). iPhone 11 connects fine since AX removed.
I wonder if the RAX40 is not too sensitive to disturbances??? And last night I saw a DFS effect : 5Ghz chan changed 2 times from 56 to 36 !
So I'll not use anymore 56 and I'll try other channels...
Once channel config will be OK, I'll try AX again; I don't want to change more than 1 param at time.
Best regards
Ron
- ronald_frLuminary
Hello,
Here are my very last tests:
I used config : AX disabled ; CHAN2.4 = 1 ; CHAN5 = 48 for 3 days w/o troubles.
This afternoon, I enabled AX and there were no immediate troubles; but after a couple of hours, I got 2 known messages :
[WLAN access rejected: incorrect security] from MAC address .....iPhone 11 mac....., Mon,Apr 13,2020 17:15:34
[WLAN access rejected: incorrect security] from MAC address .....iPhone 11 mac....., Mon,Apr 13,2020 17:12:58I opened the iPhone11
- WiFi 5GHz was unreachable (trying to connect to WiFi 5GHz and no internet access)
- WiFi 2.4GHz was running
- and all other devices (not WiFi6 ) were able to connect to WiFi 5GHz !!
All I did was "STOP - START" WiFi 5GHz on the router (Advanced Setup) and the iPhone was enable to connect to WiFi 5GHz again! (not any reboot).
WE NEED a fixed Netgear's Firmware for RAX40!
Best regards
Ronald
- MaxgurGuide
I ask you to troubleshoot with connecting devices via WIFI 6, constant breaks of the WIFI signal. The cost of the device is high, but there is already no strength to suffer from disconnected connections and you just want to give the router back to the store
- brucek9AspirantIt’s a piece of **bleep**!
Don’t buy net gear bull**bleep**! Owners should be in jail for selling **bleep** that doesn’t work!!
