LightingMcQuee7's avatar
Apr 25, 2024
Rax41 router
I have a question I bought the router brand new and didn't know you had to pay over 300.00 dollars for some kind of lifetime plan is what the guy on the phone said and he sounded from overseas with an American name but they did something to my service to the point I couldn't even get online well I he said no worries you had some unwanted traffic but no worries just pat the money and you will be back up and running but I just disconnected everything and put away the nighthawk router and hooked back my starlink factory router and my service is still bad so my question is could they have done something to make my factory router not run to it's full potential.......TIA
    It was a scam!  If you placed the call, you used a phone number found with a web search.  I hope a lesson learned on your part.
    As long as you did not let the scammers connect to your router or computer, you are fine.
    First step is to perform a full firmware default (factory) reset on the router and go through the initial setup from scratch.
    You can download the manuals from the Support section at the top of this page.  Any questions you have, you can post here on the forum at no cost.
    • LightingMcQuee7's avatar
      LightingMcQuee7
      I did get it under customer support for netgear.i didn't give him any credit card numbers or no payment was made I told him I had to talk to the wife before I do so I'll call back.The code was only thing he sent to my email,Could they have sent a virus to my network cause whatever they did at first made the netgear router not usable at all and my phone couldn't find the router and the speeds went way down from 200 Mbps or higher to 100 and slowly down to 80 Mbps or lower.I new to this so sorry for asking you a lot of questions
      • Kitsap's avatar
        Kitsap
        Master
        Very doubtful.  I recommended the default reset to be sure.
      LightingMcQuee7
      I just searched netgear support and called the number.What had happened they did something to where I couldn't log in the netgear app I downloaded off the Google play store and it kept saying wrong password so I called and he said I have some unwanted traffic but no worries I have 3 options and the 3rd one was a lifetime deal for 300 dollars and he sent some code to my email I read it back to him and he asked what I wanted to pay I just told him I'd call back he said OK they close in a Lil bit I never called back I haven't used router since but my internet hasn't been the same ever since all this has happened.
      • michaelkenward's avatar
        michaelkenward
        That was a Google search? Google is happy to sell ad space to any crook that pays up.
        This can show a number that has nothing to do with Netgear. Talk of paying for an additional security service is a giveaway.
        Netgear warns about these scams.
        How do I identify an official NETGEAR website or social media account? - NETGEAR Support
        If you have problems getting something to work, and you are within the 90 days for free support, then contact Netgear through the official channels:
        Contact Us | Support | NETGEAR
        First you have to register your device to confirm that it is eligible for the 90-days free support.
        MyNETGEAR | Product Registration
        Start a case and, with luck, they will contact you.
        After 90 days, there is also a paid-for channel
        NETGEAR ProSupport for Home | NETGEAR
        The $300 number is a giveaway. Premium support costs just $99.99 a year at most.
        Or you can try to sort out problems here. It costs nothing.
        Many problems are pretty straightforward. A search in this community may throw up something helpful.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    LightingMcQuee7
