Qwikpanda
Jul 31, 2026Aspirant
Rax80 dynamic qos settings
Hello I have a plan for up to 1 gig download speed and 40 upload.what would be the best inputs to add for download and upload speed.i game wired for call of duty.i know they said it is recommended to leave qos off with that much download but when I have qos enabled my shots are more responsive and my ping is more stable.i was on an old router when there was only uplink upstream qos but now I need to input download for dynamic qos.if anyone have any ideas please and thank you
I would not use QoS. I've not used QoS on my 1G.50Mbs ISP service for years. QoS isn't really needed for these higher ISP services as gaming speeds don't use the max download or up load.
Game all the fine with out it. I find that ethernet connected gaming devices is most recommended for best gaming performances.
- QwikpandaAspirant
Ok..what about disable port scan and ddos protection and sip alg should those be checked or unchecked in box for better gaming performance?
Leave that unchecked unless you have a SIP phone that needs it.
- QwikpandaAspirant
I am wired. I have also other family members that stream off YouTube and play on pc but they are on Wi-Fi.it just feels my shots connect more when I had qos enabled.but I am not sure what would be the correct input for dl speed to put for qos
Try using what the on board speed test results in for you ISP service.
