M-E
May 07, 2019Tutor
RAX80 loses changes to connected device configurations
I change type of device, model of the device, and name of the device for my connected devices and then apply my changes. (I apply after each device) and the changes appear to take affect. I can refre...
M-E
May 07, 2019Tutor
Wow! Opened a support ticket about this... they updated the ticket and asked me to call them... I did... they had absolutly no clue what I was talking about and asked if a Sr engineer could call me back! This tells me that they NEVER looked at the ticket before asking me to call in ithrewise I would have gone straight to someone who could help me rather than wating 30 minutes of my time.
So far I am not a fan of the Netgear product or the support that they dont really seem to offer. Sure hope someoine even wants to change my opinion.
Sanjonline
Aug 09, 2019Tutor
Haha That is amazing, I have logged the exact ticket same issue with support over 6 months ago, and they said the same thing to me. First they didn't understand what I was talking about and then they said they had never head of this issue before, then it was due to user errror, then it was escaleted to senior engineer, who also didn't understand what saving the config meant, nor how to configure the device with out using the wizard, or the andriod app. I first logged the ticket after the update V1.0.1.40 when they screwed up the firmware and basically broke the AX80, since then they havnt bothered to fix the issue, instead just they just keep bring out firmware that seems to just break the things that are left working on the device and don't bother trying to fix the things they broke in the last firmware. The issue has been sitting with them for so long now my device is out of warranty and to get it looked at I need to buy the extended warranty and support which is just as much as buying a Meraki AP with 3 years licenses which is what I have done. Once upon a time Netgear products we good, now days the hardware is good, the implementation and software is below standards and full of bugs and issues. This all started when netgear decided to start forcing people to use a wizard to set it up and blocking the device from manually configuring the device. By blocking manual configuration the stopped the ability to be able to save the router config to the devices rom or the ability to configure the device on your own network. Now we are stuck on using a default configuration that can't be changed or modified, I can only assume so that netgear can minimise support issues that require critical thinking and troubleshooting skills for their support staff.
The RAX80 makes a very good paperweight or tablet stand, but a on the expensive side. As WiFi AP unfortunatly they killed that function a while ago.
- AutomanAug 12, 2019Apprentice
Indeed, the web interface on the RAX80 is very poor and have to scroll up to the top of the page to click on edit after selecting a single device tick box makes me think the testing must have been next to none existant.
Not only does it not tend to save device configurations and device type icons for more than a couple of hours the team that wrote the android app must have been working from a different spec as the device type icon list is different from those avaialable in the web interface.
The list of device types in the web interface is not even any kind of order (too complicated I guess for the software engineers).
- NickR40Sep 26, 2019GuideHi. I too am facing this issue where my rax80 is not saving it’s settings.
I created a conversation but not having much luck from Netgear.
Using the original firmware’s debug page I was able to enable telnet. I found that the data jffs2 partition is full due to httpd_dbg.txt growing out of control. Any attempt to delete or truncate the file gives an error. Not enough space on device. So I get the feeling that because this partition cannot be written to it will not save any new settings changes.
So how can we format this partition and how do we stop the log doing this again?
