NickR40
Sep 18, 2019Guide
RAX80 recalls previous settings after factory reset
I have been trying to reconfigure my RAX80 router however each time I make a configuration change that requires a reboot, the router boots back to its previous configuration. I went to the Backup...
michaelkenward
Sep 19, 2019Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
NickR40
Sep 19, 2019Guide
Hi
I have firmware 1.0.1.62_1.0.26
Thanks for your help.
