NickR40
Sep 18, 2019Guide
RAX80 recalls previous settings after factory reset
I have been trying to reconfigure my RAX80 router however each time I make a configuration change that requires a reboot, the router boots back to its previous configuration. I went to the Backup...
michaelkenward
Sep 19, 2019Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
NickR40
Sep 19, 2019Guide
Where might I find these new versions or hot fixes that you have suggested?
thank you
- michaelkenwardSep 19, 2019Guru - Experienced User
If you visit the support pages:
you can feed in the model number and find all the documentation and stuff for your hardware.
- NickR40Sep 19, 2019Guide
Yes as you might imagine, i have done all that.
I feel this needs a next step. Beyond the 30:30:30 wipe. Is there a way to forceably erase the nvram?
Is there some commands or software that can do this kind of thing? Right now im entering the fourth day of this and i cant progress because every time the router reboots it just reverts to old configuration.
Anything else applicable?
Thanks
- NickR40Sep 23, 2019GuideHi
I think I may have identified the problem. I was able to telnet into the router and can see that the jffs devices have space issues.
On mtd:data the httpd_dbg.log file has grown to consume most of the device and any attempt I make to delete or truncate the log file just tells me that i can’t do it because there is no space on the device.
Is there a method for clearing down the jffs devices back to out of the box?
How is this log file controlled so that going forward it does not consume the space again?
Thanks for your assistance on this.
