ShadowMario3's avatar
ShadowMario3
Luminary
Apr 20, 2022
RAXE500 Daily Logs Not always working
I am having a similar issue to this topic: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAXE500-email-router-logs-daily-hourly-not-working/m-p/2090338
I am on Firmware Version: V1.0.9.78_2.0.38, which I believe is the latest firmware. I have set the sender to both gmail (using smtp.gmail.com and port 587) and aol (using smtp.aol.com and port 465) along with always creating a new app password on both accounts when I switch between them. However, though daily logs work at times, more often than not, they come up with these errors:
[email failed] fail to connect to outgoing mail server, Wednesday, Apr 20, 2022 05:00:00
[email failed] internet connection is dropped, Wednesday, Apr 20, 2022 05:00:00
When these errors show up, the router gives up on sending the email + clearing the log. Manually sending the log through clicking the "Send Log" button (in the Logs section) works 100% of the time with the settings set to either email, so I know that the username, passwords, and smtp are correct. It's just automatic daily notifications where the email seems to be failing. I believe this is likely an issue with the router since I never had this issue with daily logs on my R7000P.
I appreciate any info that can help with this issue.
  • FURRYe38's avatar
    Any progress on this?
    Have you tried the newest FW version to see if this is fixed?
    ShadowMario3 wrote:
    Thanks for checking it out, completely missed your suggestion for debugging. As for the ONT I am using, I am unfortunately unable to check it since it's hidden behind a hard to reach area at the moment. The ISP is GoNetSpeed, so it's whatever they offer for fiber.
    As for the day and time options being greyed out when you are set to hourly, I'm pretty sure that is normal because hourly is supposed to send a log at the top of the hour no matter what.
  • A small update:
    I recently did a factory reset of the router and restored my settings from a backup. It seemed hourly logs were working over 24 hours. However, once I switched the setting to Daily at 5:00am, it seemed that I started to get the "[email failed] internet connection is dropped" again, even after switching it back to Hourly. Synchronizing the clock with the Netgear NTP server seems to have fixed it.
    One thing I have noticed is my old R7000P automatically synchronized the time once or twice a day whereas the RAXE500 does not automatically synchronize time at all. This might be the reason that daily logs have consistently worked on the R7000P, whereas any change to an outside setting might cause the automatic email to fail. Is there anyway to force the RAXE500 to perform automatic syncs with the NTP server?
  • I have a new RAXE500 and I am seeing this issue. Did you have a resolution or workaround? Firmware v1.0.10.86_2.0.40
    • ShadowMario3's avatar
      ShadowMario3
      Luminary
      After firmware V1.0.10.82, it seemed to be behaving consistently as long as I set it to hourly logs. I made sure to set up the sender with a gmail account (used an app password due to 2FA). After that was done, rebooting the router made hourly logs consistent. I noticed that changing any setting (email setup, Address reservation, NTP sync) would throw it off again, so after changing the setting, I would have to reboot the route to get the logs to sent consistent emails.
      • FURRYe38's avatar
        What is happening exactly when email logs are working then you make a change as you mentioned? Are the logs failing to be sent or do the log contents not look right?
