theMPG
Dec 13, 2021Tutor
Replacing BT Home Hub 6 with DrayTek Vigor 130, then connecting to my Nighthawk RAX200, step by step
Replacing my BT Home Hub 6 with DrayTek Vigor 130, then connecting to my Nighthawk RAX200, step by step guide if possible.
Hi. Looking for some not-too-techie guidance and help, if possible.
My plan is:
- I replace my existing BT Home Hub 6, with a DrayTek Vigor 130 modem
- then, attaching my Netgear Nighthawk RAX200 to my new DrayTek Vigor 130 modem.
- Can anyone give me 'an idiots guide' for how to configure my RAX200 for perfect harmony, between the Vigor130 and the RAX200 units.
- do I perform a factory reset of the RAX200, so automatic configuration can sense the v130 modem and pick up up those settings
- do I perform a factory reset of the RAX200, and manually set-up each section? If so, how... what should the settings be...?
Any guidance, would be gratefully received. I want to slowly get the units into place, knowing I have reduced the option of failure, as much as possible.
I have been advised I need to consider PPPoE, and DHCP. I also understand the Vigor will be in Bridge mode, which then leaves the RAX200 to manage the DHCP, and I have obtained then PPPoE information for my BT Broadband provision.
You now know, all I know... but how do this... where to start, and each step until completion..
Many thanks,
Martin (London)
Thanks so much. Quite often it's knowing where to get the answer to the problem, but knowing what to ask, is often the bigger issue.
I greatly appreciate the forum details, heading there now, to see what's what, or ad a post.
many thanks, 👍
- theMPGTutor
I heard this community was good, but the support has been amazing. I was initially a little worried that I was asking a 'stoopid' question, but everyone has been so encouraging with guiding me through this.
the changeover will with be this weekend or next, commitments allowing.
I greatly appreciate everyone's guidance..l everyone has to start done where, right... 😉👍
Come visit anytime you need. :smileywink:
Turn off and unplug modem.
Turn on computers and rest of network.Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.- theMPGTutor
many thanks, 👍
