Slimoune's avatar
Slimoune
Impossible de se connecter RNDU2000
Bonjour à tous,
Depuis quelques jours je n'arrive plus à me connecter à mon ReadyNAS Ultra 2 (RNDU2000).
Je n'ai pourtant pas fait de modif du mot de passe. J'y accédais via l'explorateur de fichiers windows (win 11) sans problème.
J'ai essayé la procédure OS reinstall  page 15
https://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_FR_02Aug11.pdf
, il a réinitialisé l'adresse ip en 192.168.168.168/admin . Hier, j'avais la fenêtre qui me demande le mot de passe et aujourd'hui plus de fenêtre. J'ai juste changé de carte réseau du NAS.
J'ai sauvegardé les données sur un autre support au cas où.
Si certains d'entre vous ont une solution je suis preneur.
Merci par avance pour votre aide.
ps:
Windows 11
Firefox
TLS1.0
  • I'm not completely following what you are saying (I have to use Google Translate), but an OS re-install does not set the IP address to 192.168.168.168.  It sets it to DHCP and the default IP that gets set when DHCP isn't working is 192.168.168.168.  If you are trying to connect to the NAS directly with your computer rather than via a router with DHCP, you can address it via that IP address, but the PC will also have to be set to an address in the 192.168.168.xxx range.
    • Slimoune's avatar
      Slimoune
      That's what I did. I connected the NAS directly to the PC. I reset the password, but I'm not receiving the password.
  • Thanks Sandshark,
    Thanks.
  • I don't understand what you mean when you say you are not "receiving the password".  Do you mean that after successfully making the change you no longer get a password prompt when you attempt to log in?  If so, what do you see instead?  Is your PC still set for an IP address of 192.168.168.xxx and directly connected to the NAS?  Does RAIDar see your NAS and what status does it show if it does?
    • Slimoune's avatar
      Slimoune
      Excuse me, perhaps I wasn't clear. Yes, indeed, I no longer had the username/password prompt.
      I reinstalled the OS, and the prompt reappeared. When I go to "configure" in Raidar, I have an address in the format 192.169.168.168/admin, but unfortunately, the username: admin and the password: netgear1 don't work!
      Yes, Raidar correctly detected the NAS and all the indicators are green
      • Sandshark's avatar
        Sandshark
        Sensei
        Has your NAS been converted to OS6?  If so, the default password after an OS re-install is password.
  • Hello,
    I performed a factory reset and have been waiting for 24 hours. The process is still not complete!
    In column "i", it still says "erasure".
    Thanks for ur help.
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
ProSupport for Business
