Magno's avatar
Magno
Follower
Aug 11, 2017
AC 1900 cable modem and AC3200 x6 wifi router
My problem is that I try to connect my wifi router with my modem that I just bought but it is asking me to disable wifi gateway from my existing wifi which is the modem. How can I disable it so that I can use my AC3200 x6 wifi router to its max.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello magno
    You modem should have a modem only mode or you would have to disable the DHCP server on the modem.
    DarrenM
