afredwing's avatar
Oct 15, 2022
AX2700 Slow Speed
I have an AX2700 (cax30) modem and router combination.  I am connected via cable to xFinity with a 800MBS speed/plan.  According to my Nighthawk app my internet speed is 600MBS.  My computer/phone is 12 feet away from router and I am only getting 90MBS, the other floors in the house get 70-80 MBS.  All my TV's are having to buffer or will pixelate fairly often.  I am auto channel for both 2.4 and 5.2 bands.  Do you have any suggestions as going from 600MBS to 80MBS does not seem possible?  Thank you in advance for any help.
  • plemans's avatar
    Are you using smart connect?
    If so, try disabling that. then test the difference in speed from the 2.4ghz to the 5ghz.
    2.4ghz is a slow network and sensitive to interference. You should have your streaming devices and higher performing devices on the 5ghz.
    • afredwing's avatar
      afredwing
      Tutor
      Plemans - thank you for the response.  After I sent the post in I called Xfinity to see what they are seeing and ensure I am provisioned correctly.  Interesting, I actually have 1.2GB speeds from Xfinity but now - 150MBS is all I am seeing on my devices. Today, I tried to reset everything back to factory settings, and just reset it all up again.  No change in speeds.  I also turned off smart connect and no difference.  it looks all my devices are now on 5GHZ accept the router (should that be the case).  Xfinity is now coming to my house this week to see what they can find.
      TY again for the help.
      • plemans's avatar
        Do you have a screensnip of the cable connections page and the event logs?
        Those help us check the line as well and give you info to xfinity when they come or helps to prevent an issue interior to the home.
