JohnSullivan's avatar
JohnSullivan
Buying a cable modem with voice for Comcast
I am currently using an ARRIS SB6121 Cable Modem with a Netgear R6200 Smart WiFi Router.  Comcast shows that my cable modem is not supported so I'm looking for one that is. I recently upgraded my comcast to Triple Play with Voice, so the recommended modem is a Netgear C7100V.  When I search to purchase this modem, the recommendations are to purchase Netgear Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem Router Combo.   But, since I already have a very decent Netgear Router, why should I purchase the combo?  I can't seem to find just the Netgear C7100V
  • wait for CM500V to be in stock and use that with R6200 router you have.
    CM500V is modem-only + Voice device (no Router + WIFI).
  • > [...] Netgear Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem
    > Router Combo [...]
       Not a model number, is it?
    > [...] I already have a very decent Netgear Router [...]
       Also not a model number.
    > Model: R6200v2|AC1200 Dual Band Gigabit Smart WiFi Router
       Is it that?
    > [...] I can't seem to find just the Netgear C7100V
       Visit http://netgear.com/support , put in your prospective model
    number ("C7100V"), and look for Documentation.  Get the User Manual.
    Read, to learn what you think that you want really is.
       On the bright side, you could probably configure your existing "a
    very decent Netgear Router" as a wireless access point, and use it to
    improve your wireless coverage.  (Look for "Wireless Access Point" in
    the R6200v2 User Manual, for example.)
    • JohnSullivan's avatar
      JohnSullivan
      Your answer was not useful, however vkdelta (Netgear employee) did provide the answer I needed.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
      JohnSullivan
      Yes, this is one that I saw was listed as compatible, but I couldn't find a place to order it. As you indicated, it's "Temporarily out of stock". I placed an order via Amazon.com and I guess I'm on a holding pattern until there is a product available to ship. Thank you very much vkdelta.
