Helpmeplease1
Dec 14, 2016Aspirant
C3000 blinking green lights, no internet
Hello- please help. The other day my wifi stopped working. There were no power outages, I did not change the location of the router, or interfere with it in any way. The power light stays solid ...
Retired_Member
Dec 14, 2016Push reset continuously for 90 seconds
1st 30 with power
2nd 30 no power
3rd 30 with power....it should reboot and and DS should blink for a bit....then stop....upstream then starts blinking as it trys to link to ISP.
If down stream LED does not go solid green, check cable signal and or call cable company. After DL goes solid UP Link should start blinking and after several minutes go solid green if not call ISP.
The MODEM may have failed too.
read the manual too regarding troulbshooting using LEDS
