Helpmeplease1
Dec 14, 2016Aspirant
C3000 blinking green lights, no internet
Hello- please help. The other day my wifi stopped working. There were no power outages, I did not change the location of the router, or interfere with it in any way. The power light stays solid ...
Helpmeplease1
Dec 17, 2016Aspirant
Thank you for the tip. After making my original post, I held the factory reset button for about 5 minutes. It actually went through the reset and began working again!
Unfortunately it just stopped, after 3 days of working fine. Same exact issue as before. I tried holidng the button for a while, and your recommendation, but neither changed the blinking sequence.
If the modem failed, will NetGear refund me?
Anonymous
Dec 17, 2016Go to MyNetgear .....support.....replace my defective device......."TELL THEM IT WILL NOT POWER UP" if it's less than 1 year old
