Savvy_Thoughts's avatar
Jan 09, 2017
C3700-100NAS is blocking ip Camera. I cannot see the ip address at all and do not know mac address
Normally, I have an issue setting up a new ip camera, because the router blocks the new ip address immediately. When the router blocks it I am unable to see the ip address at all, not even in the blocked attached devices. With the other cameras I have setup I was given the mac address (located on the camera or manual) and able to manually add it to LAN. This camera I do not have access to the mac address without being connected to it. Since my router is not even showing it attached (not even in blocked attached devices) I am at a loss of what to do.
Can anyone walk me through a way to add the camera, please? Thanks in advance!!
  • Every wireless device should have a lable attached showing the MAC address. You mean the label is removed or fell off?
    What is the camera brand name? When you say blocked, I guess router is not handing out an ip address for the camera?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Savvy_Thoughts
    You may need to look for advice on your cameras support site if there is another way to find the mac address of the camera.
    DarrenM
