jdlr's avatar
jdlr
C6300 - Cannot perform firmware upgrade - GUI missing
Hello,
I am trying to do a firmware upgrade on my C6300 router.  I have tried going to this website for instructions:
https://kb.netgear.com/000053268/R6300v2-Firmware-Version-1-0-4-20
The site suggests that I go to administration tab and select the firmware button, but the problem is on my GUI I do not have this option.  I have also tried downloading the Netgear Genie application and this also does not work.
I have seen on some forums that the ISP needs to perform the firmware upgrade, but the issue is, this is my personal router.
Does anyone know a simple workaround to this issue?  Thanks!
  • > I am trying to do a firmware upgrade on my C6300 router.
       Generally speaking, you can't.
          https://community.netgear.com/t5/x/x/m-p/1490471
       Doesn't matter.  You still can't.  If you search around, then you
    should be able to find similar responses from actual Netgear agents.
       Define "simple".  Contact your ISP.
    • jdlr's avatar
      jdlr
      Thanks for the reply.  So I purchased a router from bestbuy and I cannot perform upgrades because only a ISP, that shouldnt have access to my personal router, is allowed to...great product Netgear.
      With that being said, I am trying to connect this cable router directly to the coaxial feed from my Spectrum internet.  I was on the phone for 3 hours yesterday with tech support and the signal could not sync...it would lock in but would not sync, therefore I could not get internet connection.  The tech said that I should try to perform a firmware upgrade, since Spectrum says it should be at V2.01.22, when my current firmware is at V2.01.18 (src: https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router).
      Should I keep troubleshooting with Spectrum?
