Anonymous's avatar
Anonymous
May 18, 2021
C6300 AC1750 Cable Modem Router
The Upstream light on the front of the device is always orange.  I tried a reboot (on/off button on back).  Firmware version 3.01.04 and Cox is my vendor.  Otherwise the device seems to work properly.  Any ideas?
  • plemans's avatar
    that seems to indicate only 1 upstream channel is locked.
    Do you have a screensnip of the cable connections page (shows the upstream/downstream info)
    check your link for kinks, damage, old/bad/cheap/corroded connectors. replace them if you do.
    I'd also remove any spiltters, amplifiers, or attenuators from the line.
    • Anonymous's avatar
      Anonymous
      Upstream Bonded Channels
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA25120 Ksym/sec23500000 Hz48.8 dBmV
      2Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
      3Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
      4Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
      • plemans's avatar
        got a screen snip of the downstream and the event logs?
      Anonymous
      Any Help?
      • plemans's avatar
        that's the same upstream. Your downstream?
