TheOnlyVv
Feb 23, 2016Aspirant
C6300 Info Tab Lost
After I moved I lost the info tab that comes with the C6300. This is the tab with all of the MAC Address, Serial number etc. Info on it. This modem did not come with a sticker that has this info, nor ...
DarrenM
Feb 24, 2016Sr. NETGEAR Moderator
Hello TheOnlyVv
DId you ever register it on netgears website if so I would be able to look it up for you. Or If you are able to access the modem you can try to go to www.routerlogin.com and see if it brings up a modem page that will list that information in the advanced tab.
DarrenM
TheOnlyVv
Feb 24, 2016Aspirant
I may have registered it on the website, I can't remember. How would I find out?
Unfortunately I can't access the modem because I'm unable to activate it via my service provider without the information that comes on that info tab
- DarrenMFeb 25, 2016Sr. NETGEAR Moderator
TheOnlyVv
Just private message me your Email, Phone number, and Name that you would of registered it under and I can look it up.
DarrenM
