ozborn98
Jul 17, 2016Follower
C6300 Readyshare doesn't show hard drives
Tried connecting over 10 different USB hard drives and none would show up on the Readyshare USB list either through the routherlogin.net or through the \\readyshare on network. I then read manual and...
DarrenM
Jul 20, 2016Sr. NETGEAR Moderator
Hello ozborn98
It should of picked it up if you formatted it and then plugged it directly into the modem it could be a issue with the usb port on the modem itself. You will want to contact support if the modem is still under warranty.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
