dpswind
Jul 15, 2017Aspirant
c6300 usb port - cables do not insert fully
firmware version 2..01.18... purchased a year ago. Now I am trying to connect USB storage (Seagate Backup 4TB USB 3.0), and it appears as though the supplied cable only goes in so far. The USB ligh...
- Jul 15, 2017
the USB receptacle on the C6300 does not allow the cable to be pushed in to the shield... I believe it is normally going to look as though an 1/8" is mistakenly exposed. The setting on the genie had not affect on the USB Readyshare, however, after making all the connections and powering down, then powering on, I was able to connect to the Seagate. The Readyshare shows up now in the "Available Network Folders", and I will continue testing.
Lesson from this experience is to not trust the PNP ability with this drive.
Please keep for further updates. Thanks. -Steve
dpswind
just a follow-up... the port on the Seagate Backup Plus is an SS USB (standard USB 3.0 blue). Looking closer at the C6300 port, it is white. Let me know if there are any other details I can provide. -Steve
dpswind
hunted and pecked through genie, and found advanced usb settings to enable any usb device connected... turning this on, and will retest.
- dpswindJul 15, 2017Aspirant
Additional note to users who are configuring USB storage via Genie... turn off the pop-up blocker... the app uses pop-ups to allow you to edit or create folders.
