dpswind
Jul 15, 2017Aspirant
c6300 usb port - cables do not insert fully
firmware version 2..01.18... purchased a year ago. Now I am trying to connect USB storage (Seagate Backup 4TB USB 3.0), and it appears as though the supplied cable only goes in so far. The USB ligh...
- Jul 15, 2017
the USB receptacle on the C6300 does not allow the cable to be pushed in to the shield... I believe it is normally going to look as though an 1/8" is mistakenly exposed. The setting on the genie had not affect on the USB Readyshare, however, after making all the connections and powering down, then powering on, I was able to connect to the Seagate. The Readyshare shows up now in the "Available Network Folders", and I will continue testing.
Lesson from this experience is to not trust the PNP ability with this drive.
Please keep for further updates. Thanks. -Steve
dpswind
hunted and pecked through genie, and found advanced usb settings to enable any usb device connected... turning this on, and will retest.
dpswind
- dpswindJul 15, 2017Aspirant
Additional note to users who are configuring USB storage via Genie... turn off the pop-up blocker... the app uses pop-ups to allow you to edit or create folders.
