Bturchi1
May 26, 2020Guide
C6900 connection issues
Hello, because of this coronavirus I have been working from home, occasionally I will lose connection to the internet. The problem as far as I can figure is my up stream. The attached photo is a screenshot from my modems internet page during a disconnect. See in the upstream toward the bottom the unknown channels? Why does it do that and how do I fix it if that makes sense?
Thanks
Thanks
both your downstream has to many errors and your upstream isn't locking and is to high on power.
try removing any splitters, attenuators, or amplifiers from your line. preferablly hook the modem to right where the coax enters the home without anything in your line.
Then use it for a bit and re-run the cable connections page.
If it isn't any better, then your isp needs to check your line.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
