andreah1
Nov 21, 2019Apprentice
C7000 Locked/Unlocked Channels?
Forgive me if I'm posting in the wrong place - not technologically advanced, just trying to fix a problem. For the past week or two have noticed internet speed choppiness, especially on my desktop. I have done a speed test and looks to be what I should be getting 20 down 5 up. I just reset the router and notice my upstream and downstream (had to look them up) are amber. Would that be part of the issue? Is there something I can do to fix this? Or is it something that Spectrum would have to handle? I purchased the router - not theirs.
THanks in advance and bear with me if I don't understand, try to be as simple as you can. ;)
This would be the forum for your device:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
When you repost there, make sure to include:
1. a screen snip of your modem connections page and your logs.
2. You're paying for 20/5 speeds or are you paying for more and thats what you're getting?
3. Make sure you're testing over a hardwired connection. Wireless needs different troubleshooting so focus on first getting the proper speeds to your modem/router.
As suggested, speed test the the modem with a wired PC. Also remove any coax cable line splitters in between the modem and ISP service box as these can cause some problems. Have the ISP check and confirm signal and line quality up to the modem.
andreah1 wrote:Forgive me if I'm posting in the wrong place - not technologically advanced, just trying to fix a problem. For the past week or two have noticed internet speed choppiness, especially on my desktop. I have done a speed test and looks to be what I should be getting 20 down 5 up. I just reset the router and notice my upstream and downstream (had to look them up) are amber. Would that be part of the issue? Is there something I can do to fix this? Or is it something that Spectrum would have to handle? I purchased the router - not theirs.
- andreah1Apprentice
I did do all that and now have posted in the correct forum (no replies yet darn it). The amber lights are gone but the downstream is now constantly blinking green and internet is choppy. Spectrum checked everything on their end and said the signal is excellent. So it's got to be the router but I don't know what to do.
Reset the modem. Press the reset button for 15 seconds then release. Setup the modem from scratch.
