mastergenera1
Oct 29, 2015Aspirant
C7000 modem 802.11 type exclusion?
hi i was wondering if there is any way to tighten the C7000s wifi settings to only broadcast N on the 2.4 and only broadcast AC on the 5Ghz? thanks
please see page 67
http://www.downloads.netgear.com/files/GDC/C7000/C7000_Comcast_UM_27apr15.pdf
please change 2.4G 289 Mbps
for 5GHz, you can 600 Mbps or even lower.
AFAIK, that type of exclusion is not possible. Older routers used to have N-only modes, but I think router vendors have wisened up and withdrawn support for it. The Wi-Fi standards built in mandatory backwards compatibility into 802.11ac, so there is no concept of an AC-only mode.
- vkdeltaNETGEAR Employee Retired
Hi,
thanks for posting this question, 2.4G radio supports 256-QAM and thats why it has those rates in it. today's Sw does not support it for sure and I am not sure if there is an API on the radio interface which can do it (I am looking for it)
any reason you want to turn it off?
- mastergenera1AspirantI mainly would want to do it to improve my 5Ghz signal if possible, I own no legacy devices(N/AC only) and have found that doing so with another man got me my full paid for speed of 300mbps over AC wifi(with the current settings, 2.4Ggz gets me ~150mbps, and 5Ghz gives me 6mbps
- mastergenera1Aspirantmdm not man lol
also i wanted to say that i live in an apt complex so any way i can enhance the ability of the radios with settings. id like to have as many options as possible, my old ISP assigned mdm was a technicolor 8715D, and it had the functionality i speak of, but just failed 2x in 3 months, wasnt gonna have it and wanted my own unit. so i bought quality.
do you want to increase the power?
easy way to reduce from HT80 to H20 which will slightly boost up power at the expense of bandwidth.
So which menu is that under?
