kaiyoma
Jan 13, 2022Aspirant
C7000v2 has started dropping WiFi regularly, needs to be restarted often
My C7000v2 has started misbehaving as of last night. What happens is that first the 5 GHz WiFi network disappears without warning, then a minute or two later the 2.4 GHz network disappears. At this point, I have to physically power cycle the gateway, which fixes the problem for a while. Then, anywhere from a few minutes to a few hours later, the same thing happens all over again. I checked the UI and I'm running the latest version of the firmware (V1.03.03).
I already tried changing the channels for both WiFi networks to channel numbers that are unused in my area. This seemed to help last night, but today the same WiFi drop just happened again. What else can I check here?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Netgear has set up a community forum specifically for the Cable Modem products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.- kaiyomaAspirant
I don't know when the firmware was last updated (it's pushed by the ISP), but doing a factory reset is probably the next step here. I'll do that tonight. I'm already using channel 40 for the 5 GHz WiFi and that doesn't seem to be helping.
- kaiyomaAspirant
Wanted to give an update here. I did a factory reset on the gateway and that seems to have fixed the issues. I also removed my Android TV from the WiFi network and connected it via Ethernet, so that there's one less wireless device (this might make a big difference since the TV is doing the bulk of the streaming). I kept the WiFi channels the same as before and that seems to be fine. I have no idea why these problems happened out of nowhere, but it seems like a factory reset helps.
