Troach6's avatar
Troach6
Follower
Apr 16, 2021
C7800 power supply part number
My Power Supply Was Lost During A Move And I need To Purchase Another. Can Someone Get The Part Number For Me Please
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Netgear does not sell replacement power adapters. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
    If you search in the usual places, you may find some that say they are compatible with your Netgear device, or a model that has the same power specifications.
