ffware
Nov 26, 2018Aspirant
Can I use C3700 with Nighthawk X6?
I currently have a C3700 Modem/Router. I am planning on purchasing a Nighthawk X6 so that our household can better stream multiple devices. Can I use my C3700 in modem only mode connected to the X6? ...
- Nov 26, 2018
> So I found this in the user manual....
> "To cable your modem router to a gateway or router"
Which, as I read it, directly follows the big, blue section heading,
"Cable Your Modem Router to a Router or Gateway". Doesn't it?
> Is this the correct set of instructions?
I believe so.
antinode
Nov 26, 2018Guru
> [...] Can I use my C3700 in modem only mode connected to the X6? [...]
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Cable Your Modem
Router to a Router or Gateway" or "Change the Router Mode".
ffware
