ffware's avatar
ffware
Can I use C3700 with Nighthawk X6?
I currently have a C3700 Modem/Router. I am planning on purchasing a Nighthawk X6 so that our household can better stream multiple devices. Can I use my C3700 in modem only mode connected to the X6? ...
  • antinode's avatar
    antinode
    Nov 26, 2018
    > So I found this in the user manual....
    > "To cable your modem router to a gateway or router"
       Which, as I read it, directly follows the big, blue section heading,
    "Cable Your Modem Router to a Router or Gateway".  Doesn't it?
    > Is this the correct set of instructions?
       I believe so.
