dbyrnes's avatar
dbyrnes
Can't connect to HTTPS sites via wifi
I have a modem/router C3700.  I have not been able to connect to https sites like banks, library, or other secured sites on wifi with new Win10 laptop.  We have 3 other laptops and 2 tablets on the same wifi connection that can connect to https.  When I plug a network cable into the Win10 laptop, I can connect to https sites.  I can't figure out if there is a setting in Win10 that is keeping me off secured sites via wifi or if it's something on the router.  Any ideas?
  • MS Support updated the driver for my Qualcomm Atheros QCA9377 Wireless Adapter which was updated August 25, 2015 specifically for Windows 10, 64 bit.  Problem solved!  Thanks to DarrenM for helping.  Would give you a thumbs up if I could find it.
  • I forgot to mention that I took my laptop to a Panera and logged into their public wifi and was able to connect to https sites with no problems.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello Dbyrnes
      You may of set that laptop to treat your wifi as a public network in the windows settings which might be causing the issue you may want to try and forget the network and reconnect to it and make sure you select home network. hope to hear your feedback
      DarrenM
      • dbyrnes's avatar
        dbyrnes
        Thanks for the suggestion.  Windows 10 evidently doesn't offer the opportunity to choose Private or Public when connecting to a new wifi connection.  There's a setting in Wifi - Advanced Options that toggles on/off for "Find devices and content."  The option advises to toggle this "off" when on a public network.  Either way, my wifi network was already listed as Private.  I toggled the switch to "off" since I can connect on public hotspots, but still no connection to secure sites.
