bmpcabin
Jul 31, 2025Guide
Cax80 Astound 1gig plan, intermittent downstream flashing led
Installed a cax80 on Astound/RCN. Ast made the changes, up and running but very frequent drops and dowmstream led flashing. Tech came, found many problems with cables from pole to modem. He changed everything, added a -12 attenuator when done and signal was perfect. His test and router admin page matched, good signal numbers. Still flashing downstream led, off and on, again in a few mins. Latest firmware. My isp does not update the firmware on the cax80. I see lots of code 24,16 in the logs. What can i do? Tech support wont help unless i pay them, a lot. Thanks for any suggestions. I have tried everything i have found. Thought thenewcoax would fix this. It fixed the signal but i still have the issue.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router - bmpcabinGuide
FW is 5.1.1.8
Cable Connection
Cable Diagnostic
Status: Poor
Action:
[Partial Service]
If the Partial Service mode does not go away within a few hours (Click the Refresh button after each step):
1) Make sure the coaxial cable is tightly connected.
2) Remove any unnecessary splitters.
3) Replace any required ones.
4) Contact your service provider for troubleshooting help.
Internet Access:
Downstream Status:
Upstream Status:
Advanced Information
Frequency Start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 531 MHz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
Downstream Bonded Channels (Partial Service)
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 12 531000000 Hz -1.6 dBmV 40.6 dB 3 0
2 Locked 256 QAM 1 321000000 Hz 0.4 dBmV 41.7 dB 0 0
3 Locked 256 QAM 2 327000000 Hz 0.3 dBmV 41.6 dB 0 0
4 Locked 256 QAM 3 333000000 Hz 0.4 dBmV 41.5 dB 0 0
5 Locked 256 QAM 4 339000000 Hz 0.4 dBmV 40.9 dB 0 0
6 Locked 256 QAM 5 345000000 Hz 0.4 dBmV 41.5 dB 1 0
7 Locked 256 QAM 6 351000000 Hz 0.4 dBmV 41.3 dB 0 0
8 Locked 256 QAM 7 357000000 Hz 0.1 dBmV 41.1 dB 0 0
9 Locked 256 QAM 8 363000000 Hz 0.2 dBmV 40.9 dB 0 0
10 Locked 256 QAM 9 369000000 Hz 0.1 dBmV 40.9 dB 0 0
11 Locked 256 QAM 10 519000000 Hz -1.5 dBmV 40.9 dB 3 0
12 Locked 256 QAM 11 525000000 Hz -1.7 dBmV 40.9 dB 2 0
13 Locked 256 QAM 13 537000000 Hz -1.5 dBmV 40.5 dB 3 0
14 Locked 256 QAM 14 543000000 Hz -1.7 dBmV 41.0 dB 2 0
15 Locked 256 QAM 15 549000000 Hz -1.6 dBmV 41.3 dB 0 0
16 Locked 256 QAM 16 555000000 Hz -1.6 dBmV 40.9 dB 2 0
17 Locked 256 QAM 17 561000000 Hz -1.4 dBmV 41.2 dB 4 0
18 Locked 256 QAM 18 567000000 Hz -2.0 dBmV 41.1 dB 5 0
19 Locked 256 QAM 19 573000000 Hz -2.1 dBmV 41.2 dB 3 0
20 Locked 256 QAM 20 579000000 Hz -1.8 dBmV 41.3 dB 1 0
21 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
22 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
23 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 4 5120 Ksym/sec 36800000 Hz 40.5 dBmV
2 Locked ATDMA 5 5120 Ksym/sec 30350000 Hz 40.5 dBmV
3 Locked ATDMA 6 5120 Ksym/sec 23900000 Hz 40.0 dBmV
4 Not Locked Unknown 0 0 0 0.0 dBmV
5 Not Locked Unknown 0 0 0 0.0 dBmV
6 Not Locked Unknown 0 0 0 0.0 dBmV
7 Not Locked Unknown 0 0 0 0.0 dBmV
8 Not Locked Unknown 0 0 0 0.0 dBmV
Downstream OFDM Channels
Channel Lock
Status Modulation /
Profile ID Channel
ID Frequency Power SNR /
MER Active Subcarrier
Number Range Unerrored
Codewords Correctable
Codewords Uncorrectable
Codewords
1 Locked 0 ,1 ,2 ,3 159 675000000 Hz -0.32 dBmV 40.1 dB 166 ~ 3929 4442586075 3160852389 232
2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1 Locked 3 ,4 ,9 ,10 ,11 ,12 ,13 8 5300000 Hz 38.5 dBmV
Extended Upstream Transmit Power
Current System Time:Thu Jul 31 16:48:51 2025
System Up Time:13:33:35
Help Center Show/Hide Help Center - bmpcabinGuide
Event logs
Thu Jul 31 16:53:34 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:51:46 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:51:25 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:50:50 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:50:25 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:47:48 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:47:12 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:46:11 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:44:55 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:43:39 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:43:16 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:42:51 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:41:13 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:40:27 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:38:00 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:37:06 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:36:27 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:35:36 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:35:10 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:34:56 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:34:21 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:33:56 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:33:49 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:33:33 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:33:08 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:32:42 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:31:40 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:31:12 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:30:48 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:30:24 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:30:23 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:29:18 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:29:01 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:28:53 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:28:36 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:28:16 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:28:14 2025 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:27:51 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; Thu Jul 31 16:27:49 2025 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; - bmpcabinGuide
Logs
Logs
Current Time: Thu Jul 31 12:54:56 2025 Description Count Last Occurrence Target Source [DoS attack] ACK scan SPT:443 DPT:36578 4 Thu Jul 31 12:52:57 2025 64.121.130.14:36578 34.117.13.33:443 [login] from source 192.168.1.69 1 Thu Jul 31 12:48:41 2025 192.168.1.1:80 192.168.1.69:57770 [DHCP IP: 192.168.1.76] to MAC address ce:92:f6:45:98:05 1 Thu Jul 31 12:46:33 2025 192.168.1.76:0 0.0.0.0:0 [DHCP IP: 192.168.1.235] to MAC address ac:d5:64:21:96:87 1 Thu Jul 31 12:44:31 2025 192.168.1.235:0 0.0.0.0:0 [DoS attack] ACK scan SPT:5223 DPT:57961 1 Thu Jul 31 12:41:31 2025 64.121.130.14:57961 17.57.144.11:5223 [DHCP IP: 192.168.1.76] to MAC address ce:92:f6:45:98:05 22 Thu Jul 31 12:37:32 2025 192.168.1.76:0 0.0.0.0:0 [DoS attack] ACK scan SPT:443 DPT:35944 1 Thu Jul 31 12:29:18 2025 64.121.130.14:35944 34.117.254.173:443 [DoS attack] ACK scan SPT:443 DPT:35946 1 Thu Jul 31 12:29:16 2025 64.121.130.14:35946 34.117.254.173:443 [DoS attack] ACK scan SPT:443 DPT:35936 1 Thu Jul 31 12:29:16 2025 64.121.130.14:35936 34.117.254.173:443 [DoS attack] ACK scan SPT:443 DPT:35944 1 Thu Jul 31 12:29:15 2025 64.121.130.14:35944 34.117.254.173:443 [DoS attack] ACK scan SPT:443 DPT:35936 1 Thu Jul 31 12:29:15 2025 64.121.130.14:35936 34.117.254.173:443 [DHCP IP: 192.168.1.76] to MAC address ce:92:f6:45:98:05 29 Thu Jul 31 12:29:14 2025 192.168.1.76:0 0.0.0.0:0 [DHCP IP: 192.168.1.69] to MAC address b4:4b:d6:25:51:f3 1 Thu Jul 31 12:21:22 2025 192.168.1.69:0 0.0.0.0:0 [DHCP IP: 192.168.1.113] to MAC address 26:94:03:3f:a3:1b 1 Thu Jul 31 12:21:06 2025 192.168.1.113:0 0.0.0.0:0 - FURRYe38Guru - Experienced User
Ok, those look ok.
Need the cable connections log page please.
- bmpcabinGuide
I assume you mean this...
Logs
Current Time: Thu Jul 31 13:00:53 2025 Description Count Last Occurrence Target Source [DoS attack] ACK scan SPT:443 DPT:49496 1 Thu Jul 31 12:58:17 2025 64.121.130.14:49496 31.13.66.2:443 [DoS attack] ACK scan SPT:443 DPT:49459 4 Thu Jul 31 12:56:37 2025 64.121.130.14:49459 31.13.66.10:443 [DoS attack] ACK scan SPT:443 DPT:36578 4 Thu Jul 31 12:52:57 2025 64.121.130.14:36578 34.117.13.33:443 [login] from source 192.168.1.69 1 Thu Jul 31 12:48:41 2025 192.168.1.1:80 192.168.1.69:57770 [DHCP IP: 192.168.1.76] to MAC address ce:92:f6:45:98:05 1 Thu Jul 31 12:46:33 2025 192.168.1.76:0 0.0.0.0:0 [DHCP IP: 192.168.1.235] to MAC address ac:d5:64:21:96:87 1 Thu Jul 31 12:44:31 2025 192.168.1.235:0 0.0.0.0:0 [DoS attack] ACK scan SPT:5223 DPT:57961 1 Thu Jul 31 12:41:31 2025 64.121.130.14:57961 17.57.144.11:5223 [DHCP IP: 192.168.1.76] to MAC address ce:92:f6:45:98:05 22 Thu Jul 31 12:37:32 2025 192.168.1.76:0 0.0.0.0:0 [DoS attack] ACK scan SPT:443 DPT:35944 1 Thu Jul 31 12:29:18 2025 64.121.130.14:35944 34.117.254.173:443 [DoS attack] ACK scan SPT:443 DPT:35946 1 Thu Jul 31 12:29:16 2025 64.121.130.14:35946 34.117.254.173:443 [DoS attack] ACK scan SPT:443 DPT:35936 1 Thu Jul 31 12:29:16 2025 64.121.130.14:35936 34.117.254.173:443 [DoS attack] ACK scan SPT:443 DPT:35944 1 Thu Jul 31 12:29:15 2025 64.121.130.14:35944 34.117.254.173:443 [DoS attack] ACK scan SPT:443 DPT:35936 1 Thu Jul 31 12:29:15 2025 64.121.130.14:35936 34.117.254.173:443 [DHCP IP: 192.168.1.76] to MAC address ce:92:f6:45:98:05 29 Thu Jul 31 12:29:14 2025 192.168.1.76:0 0.0.0.0:0 - FURRYe38Guru - Experienced User
This from from this location: https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
- bmpcabinGuide
Cable Diagnostic
Status: Poor
Action:
[Partial Service]
4) Contact your service provider for troubleshooting help.Internet Access: Good
Downstream Status: Poor
Partial Service: Poor
Cable modem is in partial service mode. Your service provider might be under maintenance. Most of the time it won't affect your traffic and will automatically clear when work is complete.Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Good
Upstream Power Level: Good
Current time: Thu Jul 31 17:15:34 2025Startup Procedure
Acquire Downstream Channel: 531 MHz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
2 Locked 256 QAM 1 321000000 Hz 0.3 dBmV 41.6 dB 0 0
3 Locked 256 QAM 2 327000000 Hz 0.3 dBmV 41.5 dB 0 0
4 Locked 256 QAM 3 333000000 Hz 0.3 dBmV 41.4 dB 0 0
5 Locked 256 QAM 4 339000000 Hz 0.4 dBmV 41.1 dB 0 0
6 Locked 256 QAM 5 345000000 Hz 0.4 dBmV 41.4 dB 1 0
7 Locked 256 QAM 6 351000000 Hz 0.3 dBmV 41.1 dB 0 0
9 Locked 256 QAM 8 363000000 Hz 0.2 dBmV 40.8 dB 0 0
10 Locked 256 QAM 9 369000000 Hz 0 dBmV 40.8 dB 0 0
11 Locked 256 QAM 10 519000000 Hz -1.5 dBmV 40.8 dB 3 0
12 Locked 256 QAM 11 525000000 Hz -1.7 dBmV 40.8 dB 2 0
13 Locked 256 QAM 13 537000000 Hz -1.6 dBmV 40.4 dB 3 0
14 Locked 256 QAM 14 543000000 Hz -1.8 dBmV 40.9 dB 2 0
15 Locked 256 QAM 15 549000000 Hz -1.6 dBmV 41.1 dB 0 0
16 Locked 256 QAM 16 555000000 Hz -1.6 dBmV 40.8 dB 2 0
17 Locked 256 QAM 17 561000000 Hz -1.5 dBmV 41.1 dB 4 0
18 Locked 256 QAM 18 567000000 Hz -2 dBmV 41 dB 5 0
19 Locked 256 QAM 19 573000000 Hz -2.2 dBmV 41.1 dB 3 0
21 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
22 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
23 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
24 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
25 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
26 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
27 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
28 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
29 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
30 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
31 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
32 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 159 675000000 Hz -0.22 dBmV 39.1 dB 166 ~ 3929 4589087678 3285813660 232
Event Log
Time Priority Description
Thu Jul 31 17:14:26 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:13:08 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:11:06 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:10:41 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:10:18 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:09:24 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:09:02 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:08:37 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:07:54 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:07:05 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:06:13 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:05:37 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:05:33 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:05:28 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:05:08 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:04:45 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:04:43 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:04:06 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:02:57 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:02:38 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:01:52 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:00:53 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:00:28 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:59:19 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:58:52 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:58:44 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:57:06 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:56:25 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:56:07 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:55:42 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:54:24 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:54:07 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:53:53 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:53:34 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:51:46 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:51:25 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:50:50 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:50:25 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:47:48 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
- bmpcabinGuide
i believe i sent this, but i "saved the cable diagnostic info". Here it that text.
Cable Diagnostic
Status: Poor
Action:
[Partial Service]
Event Log
Thu Jul 31 16:47:48 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; - bmpcabinGuide
Cable Diagnostic
Status: Poor
Action:
[Partial Service]
Event Log
i keep replying to you but i can't see the reply on the thread. i'll try again.
- bmpcabinGuide
maybe i was replying in the wrong place, duh.
