RAbbott32's avatar
RAbbott32
CAX80 Completely Bricked - Only Power Light On
I'm having an issue I see that popped up a lot in the past year on this forum - I have a bricked CAX80 that has only the power LED light on. Hard reset does not work, the unit is entirely unresponsive to any of its buttons or inputs, and it is not possible to access the unit at all to attempt a firmware load. The unit was purchased two years ago, so Netgear's response was the standard "you're out of warranty, pound sand". I DM'd the moderator DarrenM of this board the other day but no response yet. Just wondering if anyone has had any luck with Netgear on any replacement or RMA in this scenario - I would like to continue using Netgear products and the CAX80 as it was great while working, but it would be insane to continue to purchase a $500 piece of hardware every two years because of what appears to be a known issue Netgear refuses to acknowledge or help with (or if I need to move on to a company that will stand behind its product).
  • plemans's avatar
    I struggle a bit with "stand by their products".
    They do. That's what a warranty is.
    I haven't seen any company that standardly replaces their products when they're a year out of warranty.
    They'd go out of business. Its why you have a set warranty period and you have to pay for extended warranties if you want to gamble. Feel free to try other networking companies if you think they'll extend their warranty out a year for free.
    In terms of your device. did you try disconnecting the coax from it and pushing and holding reset for up to 30 seconds while powered on?
    You could also try recovering it with tftp if you feel its a corrupt firmware issue.
    • RAbbott32's avatar
      RAbbott32
      Netgear caused the brick with their pushed firmware and it has affected many customers. Yes, companies tend  to compensate customers when they are the sole cause of a product failure. Regarding your recommendations, it appears you did not read my message as I tried each of those things mentioned and the product is entirely unresponsive - again, due to firmware pushed by Netgear.
  • FURRYe38's avatar
    https://community.netgear.com/t5/Cable-Modems-Gateways/NOTICE-Users-with-sudden-non-functioning-CAX80-modems/m-p/2234550
      RAbbott32
      Thank you, as stated in my initial message I have already done this but have not yet been replied to.
