LucianD's avatar
LucianD
Tutor
Jul 11, 2022
CAX80 show's NOW Only Power LED on
Hello all, I have a CAX80 that has only the power LED light on. Resets do not work and unable to access the unit at all to attempt a firmware load. Suspect hardware issue. Netgear will not allow me to send it in for repair since out of warranty period.
There is nothing wrong with my internet provider (XFINITY), because I ended up renting their equipment plug in and all worked
Is there any way to have the hardware repair?
Thanks
  • Just wondering. If you disconnect the modem from the ISP coax line and pull the power adapter from the wall out let for 1 minute then plug back in with out connecting the modem to the ISP coax line, does the modem front LEDs change behavior at all?
