ankitkshah2000's avatar
Dec 26, 2017
CG3000D keeps rebooting
Hi,
My wireless router is NETGEAR CG3000D-RG. It keeps rebooting itself. I am using Spectrum as provider and modem is owned by me. I am using TWC/Spectrum since year at same location and problem only started 2-3 weeks back. Event log in router has below messgaes when router is rebooted.
Interesting fact is, problem is not observed on weekend! Hardly observed during night hours. No logic behid it.
Problem occurs more during day time of week and causes lot of pain as I work from home. Sometimes keeps rebooting every 10 mins!.
Spectrum guy visited home yesterday and said nothing wrong with line (kind of blamed on modem).
Any help appericated!
These are the exact messages from event log of router captured during reboot,
Critical (3) - Started Unicast Maintenance Ranging - No Response received - T3 time-out
Error (4) - Missing BP Configuration Setting TLV Type: 17.8;
here is downstream/upstream current values (while it is up for 9hours- time since last reboot)
Downstream Bonded Channels
Lock Status
Modulation
Channel ID
Symbol rate
Frequency
Power
SNR
DOCSIS/EuroDOCSIS locked
Locked
QAM256
22
5360 Ksym/sec
645000000 Hz
8.1 dBmV
42.8 dB
Docsis
Locked
QAM256
24
5360 Ksym/sec
657000000 Hz
7.6 dBmV
42.2 dB
Docsis
Locked
QAM256
25
5360 Ksym/sec
663000000 Hz
7.3 dBmV
42.1 dB
Docsis
Locked
QAM256
26
5360 Ksym/sec
669000000 Hz
7.4 dBmV
41.9 dB
Docsis
Locked
QAM256
27
5360 Ksym/sec
675000000 Hz
7.9 dBmV
42.1 dB
Docsis
Locked
QAM256
28
5360 Ksym/sec
681000000 Hz
8.3 dBmV
41.9 dB
Docsis
Locked
QAM256
29
5360 Ksym/sec
687000000 Hz
8.2 dBmV
41.6 dB
Docsis
Locked
QAM256
31
5360 Ksym/sec
699000000 Hz
7.6 dBmV
41.7 dB
Docsis
Upstream Bonded Channels
Lock Status
Modulation
Channel ID
Symbol rate
Frequency
Power
Locked
ATDMA
74
5120 Ksym/sec
23300000 Hz
38.8 dBmV
Locked
TDMA
73
2560 Ksym/sec
18500000 Hz
38.5 dBmV
Locked
ATDMA
75
5120 Ksym/sec
30600000 Hz
40.0 dBmV
Locked
ATDMA
76
5120 Ksym/sec
37000000 Hz
40.3 dBmV
  • Thanks Darren for reply. I had spectrum technician visting my house and checked all lines. They do not check modem-router as it is owned by me. So after researching over internet and trying different things following solution seems to be working.
    1. Bought new A/C adapter for router from best buy (https://www.bestbuy.com/site/insignia-ac-adapter-black/5019131.p?skuId=5019131)
    2. Untouched other settings in modem/router
    Last 6 days not a single reboot observed! So I consider problem solved
  • hello, it just rebooted again at 8.50AM PST.
    Lock Status
    Modulation
    Channel ID
    Symbol rate
    Frequency
    Power
    SNR
    Locked
    QAM256
    22
    5360 Ksym/sec
    645000000 Hz
    8.7 dBmV
    42.5 dB
    Docsis
    Locked
    QAM256
    23
    5360 Ksym/sec
    651000000 Hz
    8.6 dBmV
    42.4 dB
    Docsis
    Locked
    QAM256
    24
    5360 Ksym/sec
    657000000 Hz
    8.4 dBmV
    42.3 dB
    Docsis
    Locked
    QAM256
    25
    5360 Ksym/sec
    663000000 Hz
    8.3 dBmV
    42.2 dB
    Docsis
    Locked
    QAM256
    27
    5360 Ksym/sec
    675000000 Hz
    8.7 dBmV
    41.9 dB
    Docsis
    Locked
    QAM256
    28
    5360 Ksym/sec
    681000000 Hz
    8.9 dBmV
    41.9 dB
    Docsis
    Locked
    QAM256
    30
    5360 Ksym/sec
    693000000 Hz
    8.2 dBmV
    41.7 dB
    Docsis
    Locked
    QAM256
    31
    5360 Ksym/sec
    699000000 Hz
    8.2 dBmV
    41.6 dB
    Docsis
    Lock Status
    Modulation
    Channel ID
    Symbol rate
    Frequency
    Power
    Locked
    ATDMA
    76
    5120 Ksym/sec
    37000000 Hz
    40.3 dBmV
    Locked
    TDMA
    73
    2560 Ksym/sec
    18500000 Hz
    38.8 dBmV
    Locked
    ATDMA
    74
    5120 Ksym/sec
    23300000 Hz
    39.0 dBmV
    Locked
    ATDMA
    75
    5120 Ksym/sec
    30600000 Hz
    40.0 dBmV
    Current System Time:Wed Dec 27 16:53:01 2017
    Top of Form
    Bottom of Form
    here is event log,
     Wed Dec 27 16:50:51 2017
     Error (4)
     Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0;
     Error (4)
     Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0;
  • hello,
    it restarted again at 9.30AM.
    TimePriorityDescription
     Wed Dec 27 17:33:13 2017   Error (4)  Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0;
     Wed Dec 27 17:33:13 2017   Error (4)  Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0;
     Time Not Established  Warning (5)  DHCP WARNING - Non-critical field invalid in response ;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.0;CM-VER=3.0;
    • ankitkshah2000's avatar
      ankitkshah2000
      here is another reboot and message are,
      Wed Dec 27 18:45:47 2017   Error (4)  Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0;
       Wed Dec 27 18:45:47 2017   Error (4)  Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0;
       Wed Dec 27 18:35:04 2017   Critical (3)  Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=4c:60:de:02:80:d8;CMTS-MAC=00:01:5c:67:d6:5b;CM-QOS=1.1;CM-VER=3.0;
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Your power levels are running a little high do you have a cable splitter connected to the modem if so try to remove that you also may want a tech from the ISP to come out and check your lines.
        DarrenM
