Laryke's avatar
Laryke
Apprentice
Mar 23, 2022
Channels bonds
Hello, I got this new modem and I have few problems, one is that hour time do not match, because of spring hour change (I do not think this is a problem), also I have few criticals and warning on event log about "Dynamic Range Window violation", "Started Unicast Maintenance Ranging - No Response received - T3 time-out;" Time Not Established
And the last one is that I have only 8 upstream bonded channels but only 4 of them are locked, I tried to talk to an Xfinity agent about this but it says it is modem problem.
  • plemans's avatar
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line.
    Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
    Once you've done that. try it, if it doesn't help, take a screensnip of the cable connections page and event logs and post back here.
    • Laryke's avatar
      Laryke
      Apprentice
      I tried some of the things you said and now I got this, the only warning, rest of them are notices
      REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value
      But I do not understand why 4 of them are not locked
      Upstream Bonded Channels
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA25120 Ksym/sec16400000 Hz41.5 dBmV
      2LockedATDMA35120 Ksym/sec22800000 Hz41.5 dBmV
      3LockedATDMA45120 Ksym/sec29200000 Hz41 dBmV
      4LockedATDMA55120 Ksym/sec35600000 Hz40 dBmV
      5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
      6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
      7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
      8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
      • plemans's avatar
        Its pretty standard for only 4 of the upload to lock.
        But it helps if you have the screen snips of upload/download the the logs.
