dmulholland95's avatar
May 12, 2017
CM1000 / MOCA 2.0
Is the CM1000 modem capable with the Actiontec 6200 moca adapter ? Also the Nighthawk X10 ?
    From what I saw it should be the CM1000 would the Nighthawk X10 and then the Actiontec 6200 moca adapter.
    The coax cable from the wall to the CM1000 input and a lan cable from the lan port of the modem to the internet port of the Nighthawk X10 R9000 router and a lan cable from one of the lan ports of the router to the Actiontec 6200 lan port.
  • Currently the actiontec has the direct outside line , output feeds the modem. Ethernet is run from the actiontec to the router.
    • William10a's avatar
      William10a
      Master
      If it is working it much be more then one way too connect the device.
