SuperNASman's avatar
SuperNASman
CM1000 DOES NOT work with Suddenlink
Well, the word is in.
CM1000 Modem (FW 2.01.14) DOES NOT work with Suddenlink.
Suddenlink came out and couldn't get it to provision. I'm just upset that I had to be the tester. Phone tech support couldn't get it to work either. They couldn't even get it to work with my existing 200Mbps plan, let alone gigabit.
Just wanted to let people know so that they don't waste $180 on the CM1000 modem, at least if they have Suddenlink for an ISP. I'll be leaving reviews on Newegg and Amazon shortly to spread the word.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello SuperNAsman
    This is a Docsis 3.1 modem that works with Xfinity internet and other providers in the future I would suggest contacting your ISP to see what modems they support before making a purchase.
    DarrenM
    • SuperNASman's avatar
      SuperNASman
      Actually DarrenM, I did contact my ISP and see what modems they support before I made the purchase. Suddenlink said they supported the CM1000, but they were wrong.
      Definition of a crapshoot.
      • vkdelta's avatar
        vkdelta
        NETGEAR Employee Retired
        I did see your log on other forum channels (assuming you are same person). it looks like modem was not correctly provisioned modem was not downloading config files.
        Please post your event log here.
  • Has anyone found the issue for this? And why suddenlink keeps saying the modem is compatible and cant get it to connect?
    • WoodchuckTX's avatar
      WoodchuckTX
      I very much hope Suddenlink will figure out how to support this modem.  The Arris router they have rented me with provides horrible performance for video conferences, etc because of the Puma 6 chipset latency.  If we can't get this working I'd like to try a 24 channel modem, but I'm not sure if they'll activate it.
      • Techlore's avatar
        Techlore
        Apprentice
        According to the CM1000 on Amazon it is compatible with Cox and Comcast. I would check there and see if it ever get's added, I'm sure NETGEAR would be all over adding Suddenlink, among others to that list. Pretty sure only Comcast was listed originally.
        If you want to use it make sure that you contact your ISP first.
