mr_sf
Oct 15, 2019Aspirant
cm1150v wall mount?
Can the CM1150v base be removed? Don't worry... if I remove the base it will be properly ventlated on all sides. I just want to confirm the base is removable thx
Oct 15, 2019Guru - Experienced User
i don't have a cm1150v but both my cm1100 and cm1000 have a torques screw on the bottom that could be used to remove the base. It probably voids your warranty as they really do need that position for airflow or they'll overheat.
