mr_sf
Oct 15, 2019Aspirant
cm1150v wall mount?
Can the CM1150v base be removed? Don't worry... if I remove the base it will be properly ventlated on all sides. I just want to confirm the base is removable thx
Efficcial
Sep 06, 2020Aspirant
Were you ever able to find a wall mount??
- mr_sfSep 07, 2020Aspirant
No.... i just ended up taking the base off and having it stand up on a wall mount wire hanger meant for ties. the cables are easily routed through the bottom of the hanger. not elegant, but seems to work. actually has a little air flow on the wall side.
