Ashhan's avatar
Ashhan
Guide
Dec 15, 2021
CM1200 Dropping Connection
For the past 2-3 weeks my internet connection has been spotty, my connection drops about 3-4 per hour, for durations of 45 seconds - 5 minutes. Getting high ping/bad connection in games, media streaming is spotty and choppy etc. I read a lot of people recommending having a technician to come out and look at the connections coming into my house. Earlier today I did just that, and a technician came and to my surprise he ran a new cable from their box to my house, and straight into my modem. Alas nothing has changed. I was hopeful as for a few hours the connection was great, consistent, and strong. Started playing some video games and once again, bad connection.
Here is a picuture of my logs: https://imgur.com/a/Mk2Y4vW
  • Here is the cable connection log:
    Startup Procedure
    ProcedureStatusComment
    Acquire Downstream Channel453000000 HzLocked
    Connectivity StateOKOperational
    Boot StateOKOperational
    SecurityEnabledBPI+
    IP Provisioning ModeIPv6 Onlyipv6Only(1)
    Downstream Bonded Channels
    ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
    1LockedQAM2561453000000 Hz6.2 dBmV43.6 dB00
    2LockedQAM2562459000000 Hz6.1 dBmV43.4 dB00
    3LockedQAM2563465000000 Hz6.5 dBmV43.6 dB00
    4LockedQAM2564471000000 Hz6.6 dBmV43.4 dB00
    5LockedQAM2565477000000 Hz7 dBmV43.2 dB00
    6LockedQAM2566483000000 Hz7.1 dBmV43.6 dB00
    7LockedQAM2567489000000 Hz7.3 dBmV43.7 dB00
    8LockedQAM2568495000000 Hz7.3 dBmV43.7 dB00
    9LockedQAM2569507000000 Hz7.6 dBmV43.7 dB00
    10LockedQAM25610513000000 Hz7.7 dBmV43.7 dB00
    11LockedQAM25611519000000 Hz8 dBmV43.8 dB00
    12LockedQAM25612525000000 Hz7.8 dBmV43.6 dB00
    13LockedQAM25613633000000 Hz7.9 dBmV42.7 dB00
    14LockedQAM25614639000000 Hz6.9 dBmV42.4 dB00
    15LockedQAM25615645000000 Hz8.1 dBmV42.9 dB00
    16LockedQAM25616651000000 Hz8.2 dBmV42.9 dB00
    17LockedQAM25617657000000 Hz8.2 dBmV43 dB00
    18LockedQAM25618663000000 Hz8.2 dBmV42.8 dB00
    19LockedQAM25619669000000 Hz8.1 dBmV42.8 dB00
    20LockedQAM25620675000000 Hz8 dBmV41.9 dB00
    21LockedQAM25621681000000 Hz8.2 dBmV42.8 dB00
    22LockedQAM25622687000000 Hz8.2 dBmV42.9 dB00
    23LockedQAM25623693000000 Hz8.2 dBmV43 dB00
    24LockedQAM25624699000000 Hz8.2 dBmV43 dB00
    25LockedQAM25626705000000 Hz8.2 dBmV43 dB00
    26LockedQAM25627711000000 Hz8 dBmV42.9 dB00
    27LockedQAM25628717000000 Hz8.2 dBmV42.9 dB00
    28LockedQAM25630729000000 Hz8.1 dBmV42.7 dB00
    29LockedQAM25631735000000 Hz7.9 dBmV42.5 dB00
    30LockedQAM25632741000000 Hz8.2 dBmV42.8 dB00
    31LockedQAM25633747000000 Hz7.9 dBmV42.4 dB00
    32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
    Upstream Bonded Channels
    ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
    1LockedATDMA335120 Ksym/sec17800000 Hz48.8 dBmV
    2LockedATDMA345120 Ksym/sec24200000 Hz48.8 dBmV
    3LockedATDMA355120 Ksym/sec30600000 Hz49 dBmV
    4LockedATDMA365120 Ksym/sec37000000 Hz49.3 dBmV
    5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
    6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
    7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
    8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
    Downstream OFDM Channels
    ChannelLock
    Status
    Modulation /
    Profile ID
    Channel
    ID
    FrequencyPowerSNR /
    MER
    Active Subcarrier
    Number Range
    Unerrored
    Codewords
    Correctable
    Codewords
    Uncorrectable
    Codewords
    1Locked0 ,1 ,225266000000 Hz6.9 dBmV43.9 dB148 ~ 394796631055309402230
    2Not Locked000 Hz0 dBmV0.0 dB0 ~ 4095000
    Upstream OFDMA Channels
    ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
    1Not Locked000 Hz0 dBmV
    2Not Locked000 Hz
    0 dBmV
  • plemans's avatar
    do you have an amplifier in your line?
    Your downstream signal is very strong which usually indicates you're close to a hub.
    But your upstream signal is high and that usually indicates you're quite a ways away from the hub.
    So I'm curious why its not balanced properly.
    • Ashhan's avatar
      Ashhan
      Guide
      As far as I know, we do not have an amplifier in the line.
      • plemans's avatar
        check it for amplifiers or even for splitters.
        Sometimes causing the power imbalance. And while technically both are in spec for power levels, they don't make sense.
