Ace_Card's avatar
Ace_Card
CM2050V - Latest Firmware Preventing 2.5 Gbps Passthrough on Ethernet Port
Hello all, and specifically to the moderator,
I'm reporting a potential firmware or hardware version defect where the native Ethernet port fails to pass through 2.5 Gbps speeds to the LAN, with firmware v10.01.03 (around February 2025).
Modem details:
Hardware Version: 1.01
Cable Firmware Version: V10.01.03
Note that this is one of the first series of the modem purchased back in March of 2021.  It has been in service as a reliable work horse since then (with the exception of the botched FW v9 update).  The unit is out of warranty, but still performs reliability (except for this latest defect).
The defect:
This issue surfaced after Comcast auto-upgraded my plan from 1.2 Gbps to 2.1 Gbps plan; a routine speed tests showed no improvement, maxing out at ~986 Mbps instead of the expected 1800-1900 Mbps (accounting for overhead).
Key evidence:
1. Via SSH to my router, the WAN port negotiates at 2500 Mbps full duplex:
eth0 (Int switch port: 3) (Logical Port: 3) (phyId: 1e) Link Up at 2500 mbps full duplex
2. A direct connection tests to the modem's Ethernet port:
Using my Fluke Networks CableIQ tester: Max output ~986 Mbps.
3. Xfinity onsite tech visit: Confirmed excellent coaxial signal levels from street to modem (provisioned for 2.1 Gbps). Their better and more sophisticated Ethernet tester replicated my results at ~987 Mbps directly on the modem eth port.  Additionally their tester showed the ISP service side of the modem and he ran diagnostics and reviewed the modems frequently, power and SNR levels and all appear as expected (normal).
Conclusion:
ISP (Xfinity) confirms upstream provisioning and signals are optimal; the bottleneck is within the modem.
This appears to be a firmware or perhaps a hardware version limitation preventing full 2.5 Gbps Ethernet passthrough. Since firmware updates are ISP-controlled, Netgear must coordinate a fix release.
ISP Details:
Xfinity, plan 2.1 Gbps Down / 300 mbps UP Internet
Moderator: Could you please confirm and respond on:
A. If engineering is aware and working on a fix for imminent rollout?
B. If this is new, will you escalate for investigation and potential correction?
C. Is this a possible Hardware v1.0 issue, and if so, what version is the newer CM2050V's HW Version and do they suffer the same problem?
Thanks for your attention – eager for a resolution.
  • Thank you all for your helpful input and suggestions!
    I wanted to share that my issue is now resolved.
    Initially, getting support from Netgear for my out-of-warranty modem was challenging, especially for what seemed like an "ISP-side firmware" issue. I couldn’t open a case via phone or chat without purchasing a support plan, which was frustrating. So, I turned to my ISP for help.
    I connected with an upper tier technician who, despite initially pointing to the modem vendor (since it’s customer owned), worked with me to troubleshoot the issue. After another reset/refresh on their end, the ethernet port finally was able to deliver the 2.5 gig expected speed (1900 to 2100 Mbps).
  • Thanks for the reply, and for confirming the HW version for all models is V1.0
    As mentioned in the original post, the router is not part of the equation and has been completely removed from all testing (except for the initial speed test that identified the issue).
    Both a Fluke LinkIQ (I mistakenly called it CableIQ in the OP) and the Xfinity tech's more sophisticated cable and ethernet testers, both connected directly to the modem with a short certified patch cable specifically designed for these types of testers, produced identical results (within a slight 1k variance, as noted in the OP).
    Xfinity confirmed that upstream provisioning is normal, and this would indicate the bottleneck is within the modem. Since HW version doesn't appear to be a factor, firmware would be the next logical item to pursue.  Unless the modem's 2.5 Gbps port capability, as stated in Netgear's marketing materials, isn't fully achievable in practice (which I doubt since prior to FW v10.01.03, I was able to get 1022 +-100 mbps using speedtest.net and nperf.com (and yes, this is a highly optimized network).
    Regarding support: The modem is out of warranty based on purchase date, so standard support requires a paid plan. Is there a way to open a ticket specifically for firmware related issues, as this might be covered without cost to the consumer?  I am unaware or able to open a firmware ticket, do you have a link or contact within Netgear where I can do this?
    From all indications, the modem seems to be functioning as intended. The Xfinity onsite tech's diagnostics passed on their devices (including the Ethernet tester mentioned and a cable tester from the ISP side). It's unlikely the Ethernet port is faulty, as it negotiates at 2500 Mbps full duplex.
    My aim is to highlight this publicly in hopes Netgear can investigate the cause and provide a workaround or solution to fixing their ethernet port on this modem. All of the consumer and ISP Operator level troubleshooting has been exhausted at this point. I'd appreciate any input from DarrenM on my three original questions.
  • CrimpOn's avatar
    CrimpOn
    It would appear that the Fluke CableIQ tester is rated for gigabit Ethernet.  Might lead to a conclusion that it is not capable of measuring higher speeds.
    https://www.aaatesters.com/fluke-networks-ciq-100-cableiq-qualification-tester-model-ciq100-fluke-networks-100.html?gad_source=1&gad_campaignid=213734576&gclid=EAIaIQobChMI_ouSn93EjwMV_TBECB33-zbKEAQYAyABEgKWSPD_BwE
    Does this router include a Speed Test that can be run on the router itself?
    Would be really helpful to have a computer with a 2.5GB Ethernet adapter that could be connected directly to the modem to run a speed test.
    It is not obvious (to me) how a customer would open a support ticket on a product purchased in 2021 (four years ago).
    • Ace_Card's avatar
      Ace_Card
      CrimpOn,
      Thanks for the reply.
      I miss identified the Fluke tester in the OP, it was the LinkIQ which is capable of 10 Gbps (borrowed from work).  However note, that the Xfinity tech's ethernet tester was also rated at 10Gbps, and it also showed 987 mbps consistently, so the two test equipment were consistent.
      As far as the router question, Yes, it has the build in speed test and along with other devices on the network was used to first identify the anomaly.
      The router has a 2.5 Gbps WAN port and as stated in the OP, negotiates at 2500 mbps Full Duplex.   Prior to the v10.01.03 updates (and still on the 1 Gbps plan), I was able to consistently achieve 820's to 1012 mbps using the built in speed test.  The speed test numbers have not changed ( I still get those speeds), on the new 2.1 Gbps plan), but I'm not getting the 1800-1900 mbps that the new Xfinity plan provides, and caps out at the 900 mbps range.
      The cable  connection at the modem is 2300 mbps, but once passing through the modem and out the ethernet port of the modem, it drops to 987 mbps (tester directly connected to the modem).
      This would in theory indicate some kind of internal issue of the modem (I was at first thinking hardware version, but FURRYe38, indicated that all the models of CM2050V have the same HW version), so HW version was ruled out at this point, unless there is a way to internally check the ethernet PHY for compliance, and it passing all consumer and ISP operator diagnostic, it is not apparent that the PHY is the problem.
      Regarding the support ticket, I agree!  Although these modems are ment to have at least a 7-10 year life span (or until DOSIS 4 arrives), it should be support for "firmware/internal", and the consumer should have a simple way to open a ticket for FW/HW level issues.
      All of the consumer and ISP Operator level troubleshooting has been exhausted at this point, so I am not looking for things to try outside of the modem, as all of the standard and professional tracing/troubleshooting back to the modem for a problem has been done.  All logs and connections status have been verified by Xfinity as good.
      • FURRYe38's avatar
        You'll need to make contact with NG support then.
  • FURRYe38's avatar
    Theres only one HW version of the CM modems.
    What is the brand and model# of the host router connected to the CM modem?
    What speed test app or site are you using to check speeds?
