gottscpe62
Jan 29, 2016Tutor
CM600 + Router Port Forwarding
I'm trying to configure my router to port forward TCP 3389 so I can use Remote Desktop. I've tried two Netgear routers and both have the router blocking the forwarding effort. i see the router log ...
- Feb 01, 2016
The mac address is my Sony Bravia TV. I've turned that wireless off and now it is forwarding - but mcafee firewall is blocking. i will fix that - thanks for your help.
gottscpe62
Jan 30, 2016Tutor
Thanks for the message. I didn't set up MAC access control so any suggestion on how I can turn it off?
TheEther
Jan 30, 2016Guru
What's the model of your router?
