gottscpe62
Jan 29, 2016Tutor
CM600 + Router Port Forwarding
I'm trying to configure my router to port forward TCP 3389 so I can use Remote Desktop. I've tried two Netgear routers and both have the router blocking the forwarding effort. i see the router log ...
- Feb 01, 2016
The mac address is my Sony Bravia TV. I've turned that wireless off and now it is forwarding - but mcafee firewall is blocking. i will fix that - thanks for your help.
TheEther
Feb 01, 2016Guru
I see two things that are likely unrelated:
- The incorrect security log indicates that you have a device that does not have the correct Wi-Fi password. Do you recognize the MAC address?
- The LAN access from remote seems to show that port forwarding to port 3389 is working.
gottscpe62
Feb 01, 2016Tutor
