bodosom
Apr 15, 2016Aspirant
CM600 error counts still zero after three days.
I've had a CM600 on-line for 3 days and the downstream error counts are still zero. Is this a firmware issue or a hardware fault or did my line become amazingly error free for the last few days?
- DarrenMSr. NETGEAR Moderator
Hello bodosom
are you having any type of issues when on the internet?
DarrenM
- bodosomAspirant
The error counts stayed at zero so I switched to another modem which is reporting errors. Of course I don't know if that's because the CM600 was better or broken.
- Jim769Luminary
I have had my CM600 for over a month and it has only reported correctable/uncorrectable errors one time this is very unusual for my connection or any connection for that matter. The one time it did report was due to Comcast working near by. Now here is the weird part. It only showed errors on channels 1-16 channels 17-24 showed zero errors. Others and myself have concluded the only way this could happen is if the 600 is locking on all 24 channels but is only using 16 of them. Not sure what to think about this modem. May go back to my 6183.
- VE6CGXMaster
Are complaining about zero error count? You don't like good line qulity. Errors occuring on data network is common thing. If there is any other issues what is the worry? Don't knock the wood!, LOL...
- Jim769Luminary
Yes your not understanding of course we all like a clean network the point is the CM-600 does not report errors at all even unplugging the coax from the modem for 10 minutes shows 0 errors this is not right. I would rather have a modem that showed me issues then one that hides them from the user and shows nothing. It appears the system log does work as i have had a few T-3 timeouts that is normal arounf here. But as far as correctable/uncorrectable code words go zip notta only a few one time after a major outage.
- VE6CGXMaster
Please, when you start a thread be sure to make yourself clear what you are talking about. Your original post did not show that.
Too many and much communication problems every where, Sigh! I am retired now. When I was working miscommunication used to
cause so muchwasted time. Some times I had to travel overseas, or far out-reach places to find that out upsetting me often. I
worked in high level tech support business for almost half a century....Or error logging(syslog) is disabled?
