Gael94's avatar
Gael94
CM600 Xfinity: Modem Access Denied
I purchased the CM600 to pair with our Xfinity service
The setup was easy and everything is working
I attempted to access the CM600 settings with the default "admin and password" credentials and have been denied
I do not recall setting new credentials in the setup process with Xfinity, I am at a loss
How do i access the CM600 settings at this point?
Thank you
  • FURRYe38's avatar
    Disconnect the modem from the coax line. Connect a wired PC to the back of the modem. Factory reset the modem by pressing the reset button in back for 15 seconds then release. Wait a few minutes. Using a web browser, log in to the modems web page at 192.168.100.1. Attempt to gain access with admin and password. Does this work?
    • Gael94's avatar
      Gael94
      Thank you for the response
      At one point do I reattach the coax?
      Will the "reset" affect connection to Xfinity?
      • FURRYe38's avatar
        Can reattach if you gain access.
        It only resets the modem and and connection to the service. The modem will get a new IP address possibly and thats it.
