KingsKid17
Sep 04, 2017Aspirant
CM700 - Network Activity LED
I just installed Netgear Nighthawk AC1750 Smart Router. (BTW...performance increase? WOW!)
Prior to this installation, Network Activity LED was showing normal, green, flickering according to network activity, on my CM700-100NAS modem [just installed last week]. After router install, Network Activity LED now showing amber, flickering according to network activity.
All other LEDs showing steady green before AND after router install. Not having any problems (of which I am aware, anyway), but wanted to make sure this is not indicating a problem.
There was a troubleshooting chart included with the modem documentation, indicating meaning of the various colors on the different LEDs...but, I seem to have misplaced it.
your laptop or whatever you connected to the Router via hardwired ethernet connection is running on 10/100 Mbps and not Gigabit. thats why it shows BLINKING AMBER LED.
- vkdeltaNETGEAR Employee Retired
you can find quick start guide and user manual in PDF format on netgear support website.
- KingsKid17AspirantWould an (old) HP LaserJet 4250, hardwired to the router, cause the same thing?
As long as it is not warning of a problem, I am okay with it. Just paranoid, after a month-long wi-fi battle! First ISP line cut, then upgraded modem, per cable guy recommendation, then router because of wi-fi calling (T-Mobile) issues.
Still have antique printer and PC. Those may not get upgraded for a while! LOL!
Anyway, thank you for the answer. Helped a lot!- vkdeltaNETGEAR Employee Retired
what Router do you have?
