Duckdoger's avatar
Duckdoger
CM700 Administration
Can anyone help.  I can access the CM700 through Netgear genie but a limited menu comes up.  Only tabs visible are Basic and Advanced and each has a very limited number of selections.  I'd like to do some port forwarding but can't seem to find out how to get to a more robust administration menu.
Appreciate anyone's help
DuckDoger
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Duckdoger
    The CM700 is a modem not a router you would need to log into your router in order to port forward.
    DarrenM
    • Duckdoger's avatar
      Duckdoger
      Hey... thanks DarrenM, good point however would you know how to get to the larger menu offerings.  I can see a larger menu when first logging in but then it quickly reduces down to limited options.  Almost like logging in with a role lesser than an admin role.
      Thanks for the response
      Duckdoger
      • DarrenM's avatar
        DarrenM
        Hello Duckdoger
        My guess is you cant and that is limited by the ISP for some reason.
        DarrenM
