joe_attaboy
Jul 16, 2017Follower
CM700 ethernet port with switch
I'm considering replacing my current cable modem with the CM700 Netgear modem/router. This model has one gigabit ethernet port. The wireless router is an R7000 set up in AP mode. That router will...
CharliesTheMan
Dec 03, 2017Aspirant
You'll want to connect the R7000 to your CM700, and of you're trying to bridge from your modem to another room wirelessly, add an access point there. The modem doesn't have routing abilities and if it did I think you'd have issues with multiple IPs.
I can vouch for the CM700/R7000 combo, works great for me with gigabit service.
