MayBTime2Change
Jun 06, 2017Tutor
Comcast customers: will Firmware V3.01.14 fix my N450 (CG3000Dv2) connectivity issues?
For the past half a year, my N450 (CG3000Dv2) cabel modem router has been completely unreliable. It regularly drops connection. Sometimes restarting helps, sometimes it doesn't. I've rebooted the box...
MayBTime2Change
Jun 10, 2017Tutor
DarrenM wrote:Hello MayBTime2Change
Are you just having wifi connection issues or is the modem dropping wired and wireless connections?
DarrenM
Great question - it's dropping both. We use wireless for most of our devices, but our Apple TV is hooked up to the modem directly and also gets dropped.
DarrenM
Jun 12, 2017Sr. NETGEAR Moderator
Can you post the modems logs when these drops are happening.
DarrenM
- MayBTime2ChangeJun 24, 2017Tutor
And here are some data from the "Logs":
[Description Count] Last Occurrence[TCP- or UDP-based Port Scan ] 1 Sat Jun 24 16:57:24 2017
[Internet connected ] 1 Sat Jun 24 16:54:52 2017
[TCP- or UDP-based Port Scan ] 1 Sat Jun 24 16:54:52 2017
[Firewall Up ] 1 Sat Jun 24 16:54:47 2017
[Public Network Interface up ] 1 Sat Jun 24 16:54:47 2017
[Time Of Day established ] 1 Sat Jun 24 16:54:28 2017
[Internet disconnected ] 1 Sat Jun 24 16:53:59 2017
[SUCCESS: User interface login ] 1 Sat Jun 24 16:52:27 2017
[FAILURE: User interface login ] 1 Sat Jun 24 16:52:06 2017
[TCP- or UDP-based Port Scan ] 1 Sat Jun 24 16:50:17 2017
[Internet connected ] 1 Sat Jun 24 16:50:17 2017
[Firewall Up ] 1 Sat Jun 24 16:50:11 2017
[Public Network Interface up ] 1 Sat Jun 24 16:50:11 2017
[Time Of Day established ] 1 Sat Jun 24 16:49:53 2017
[Internet disconnected ] 1 Sat Jun 24 16:49:07 2017
[Internet connected ] 1 Sat Jun 24 16:47:16 2017
[TCP- or UDP-based Port Scan ] 1 Sat Jun 24 16:47:12 2017
[Firewall Up ] 1 Sat Jun 24 16:47:11 2017
[Public Network Interface up ] 1 Sat Jun 24 16:47:11 2017
[Time Of Day established ] 1 Sat Jun 24 16:46:52 2017
[Internet disconnected ] 1 Sat Jun 24 16:46:12 2017
[Internet connected ] 1 Sat Jun 24 16:44:10 2017
[Firewall Up ] 1 Sat Jun 24 16:44:05 2017
[Public Network Interface up ] 1 Sat Jun 24 16:44:05 2017
[Time Of Day established ] 1 Sat Jun 24 16:43:45 2017
[Internet disconnected ] 1 Sat Jun 24 16:43:12 2017
[Internet connected ] 1 Sat Jun 24 16:42:20 2017
[Firewall Up ] 1 Sat Jun 24 16:42:16 2017
[Public Network Interface up ] 1 Sat Jun 24 16:42:16 2017
[TCP- or UDP-based Port Scan ] 1 Sat Jun 24 16:42:14 2017
Sorry for the late reply - we have a new baby in the house, so it's a bit crazy. I'm a novice, so I'm not sure which logs you want or how to post them in table form, but here are some data from the "Event Log":
Time Priority Description
2017-06-24, 16:54:29.0 Error (4) Missing BP Configuration Setting TLV Type: 17.8;
2017-06-24, 16:54:29.0 Error (4) Missing BP Configuration Setting TLV Type: 17.9;
2017-06-24, 16:54:28.0 Warning (5) DHCP WARNING - Non-critical field invalid in response ;
2017-06-24, 16:54:26.0 Notice (6) Honoring MDD; IP provisioning mode = IPv4
2017-06-24, 16:54:18.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2017-06-24, 16:54:11.0 Critical (3) No Ranging Response received - T3 time-out;
2017-06-24, 16:53:58.0 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
2017-06-24, 16:53:25.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2017-06-24, 16:49:53.0 Warning (5) DHCP WARNING - Non-critical field invalid in response ;
2017-06-24, 16:49:53.0 Error (4) Missing BP Configuration Setting TLV Type: 17.8;
2017-06-24, 16:49:53.0 Error (4) Missing BP Configuration Setting TLV Type: 17.9;
2017-06-24, 16:49:48.0 Critical (3) DHCP FAILED - Discover sent, no offer received;
2017-06-24, 16:49:35.0 Notice (6) Honoring MDD; IP provisioning mode = IPv4
2017-06-24, 16:49:22.0 Critical (3) No Ranging Response received - T3 time-out;
2017-06-24, 16:49:05.0 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
2017-06-24, 16:48:33.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2017-06-24, 16:46:53.0 Warning (5) DHCP WARNING - Non-critical field invalid in response ;
2017-06-24, 16:46:53.0 Error (4) Missing BP Configuration Setting TLV Type: 17.8;
2017-06-24, 16:46:53.0 Error (4) Missing BP Configuration Setting TLV Type: 17.9;
2017-06-24, 16:46:48.0 Critical (3) DHCP FAILED - Discover sent, no offer received;
2017-06-24, 16:46:35.0 Notice (6) Honoring MDD; IP provisioning mode = IPv4
2017-06-24, 16:46:29.0 Critical (3) No Ranging Response received - T3 time-out;
2017-06-24, 16:46:12.0 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
2017-06-24, 16:45:38.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2017-06-24, 16:43:46.0 Warning (5) DHCP WARNING - Non-critical field invalid in response ;
2017-06-24, 16:43:46.0 Error (4) Missing BP Configuration Setting TLV Type: 17.8;
2017-06-24, 16:43:46.0 Error (4) Missing BP Configuration Setting TLV Type: 17.9;
2017-06-24, 16:43:42.0 Notice (6) Honoring MDD; IP provisioning mode = IPv4
2017-06-24, 16:43:36.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
2017-06-24, 16:43:23.0 Critical (3) No Ranging Response received - T3 time-out;
2017-06-24, 16:43:11.0 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
2017-06-24, 16:42:38.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
- DarrenMJun 26, 2017Sr. NETGEAR Moderator
You have alot of T4 and T3 timeouts typically that says there is a signal issue so it would be a issue in the lines coming in your home or the ones outside. You will want to have your ISP send a tech to check things out.
DarrenM
